150rguy
I got fat bars!
654
I went riding yesterday, and I just couldn't get the rythm section type thing down, it looks like this, the jumps with the letter "i" four times
being the table tops.
/iiii\ /\ /iiii\ /\ /\ /\ /\
Ive been Jumping the first table top, going over the single thing, jumping the next table, then when I hit the ground on the table landing, pinning it it 2nd gear. But I keep on seeming to come up short jumping the single to the next single after the table top, I keep coming down on top.
Should I try It in 3rd? What else could help?
FruDaddy
2,854
Have you tried doing the first table, then stepping onto the second and possibly stepping off, then a double to a single out? Yes, 3rd might help.
150rguy
I got fat bars!
654
Ill try that
mx547
Ortho doc's wet dream
4,784
103
i agree, give it a try. i always ride a gear high and try to carry momentum rather than revving it out. i feel more in control that way.
150rguy
I got fat bars!
654
Most of the fast guys double, double, double, and single out, but I dont know if I can double those table tops to the singles yet. Maybe I just need to keep practicing.
150rguy
I got fat bars!
654
ya?
atcomx98
37
I would go with the step on step off, but you have to be totally comitted to doing it. You dont wanna fall short. Also if that doesnt work out try seat bouncing after the 2nd tabletop. to seat bounce, you stand up rduring the landing of the second tabletop and as soon as u go up the first double sit down on the back of the seat and accelerate the throttl these two things combined will preload u far enough to clear it without having to be in 2nd gear. Hope it helps.
just_a_rider
394
How far would you say they were apart? After comming off the first table into the single, how far is it to the next table and how wide are the tables?
150rguy
I got fat bars!
654
The tables are 10 feet and the single is about 10 feet away from the table.
Tho other 85 riders are either doing the first 2 tables then doubleing the singles and some are doubling the table to the single and then table to single again, then doubling and single out.
Octane250F
Uhhh...
Oct 21, 2006
174
Can you clear the first table, single and 2nd table together?
If you can clear the first table the single and the 2nd table and then double the last 4 jumps that is probably going to be the fastest way.
Even if you have to hop the 2nd table, thats still going to be faster than going over the 1 table, the single and the 2nd table seperately.
150rguy
I got fat bars!
654
Oh no I couldnt do that since the first table is right out of a corner.
Yes you can,more corner speed! You do not need a whole track,just a couple of corners,ride in any gear as fast as you can around the turn,next time faster,start on hard no rut corners,rutted corners,then berms. The faster riders will take what is needed of the corner to get enough speed to do the obstacles,you will need to go outside and carry enough momentum to rhythm more efficiently you can be faster and smoother on you. Less jumps is faster,less impacts is faster.
150rguy
I got fat bars!
654
The pros just double, double, bouble, single. The pros dont do the table the single and the other table all together.
150rguy
I got fat bars!
654
SO I should go for the double?
just_a_rider
394
So I take it thatt the top of the tables are 10'? And the single in between is 10' away from the tables? Adding all that up you could hit the first table with enough to clear the single and land on top of the other table, which if I'm taking this right would only be what about a 40 footer?
150rguy
I got fat bars!
654
uh ya maybe but I would land with enough force that it would probably bounce me off and hit the next single. Also Im not completely sure that the tables are 10' and the single is 10' away from the table. I was just estimating but thats probably close.
150rguy
I got fat bars!
654
Well I still wouldnt be able to clear it that far any way. im not that good.
