CRSpeedy
77
I just started safety wiring my grips. They were already glued. I crashed and ripped the end. Is it necessary to use glue when I will safety wire the new ones? or is that overkill?
Patman
Pantless Wonder
I do both because it's better than having only one thing that could fail. I never really wired mine until I had one that was glued let loose.
Smit-Dog
4,704
IMO, glue is unnecessary, messy, and a PITA to remove compared to just using safety wire. I've had glued grips that eventually spin, slip, and distort on the bar. With safety wire alone, zero movement.
Buy grips that have the safety wire groove; 3-4 on the clutch side, 2-3 on the throttle side. A safety wire tool is not absolutely necessary, but it does a really nice job, and makes quick work of the process.
To replace grips, just snip the wires, and the grips slide right off. No more scrapping and cutting the grip off. Very clean replacement. You can swap out grips in about 3 minutes; a little longer if you have bark busters.
adstott
65
I agree with smit. If your not a hard core racer just safety wire. I tried glue once and I'm just to stupid to use it, ended up costing me a new throttle tube and grips. With safety wire I have never had my grips move or come off.
zoommx
282
Both, especially if you run handguards that fasten into the ends of the bars; guards allow mud/water to get under grips easier. I like the extra security.
nikki
Moto Junkie
Apr 21, 2000
5,802
Just wire for us - never had a grip come off over the years. Most all grips have grooves where the wire and the wire twist should go. We primarily ride MX, but we've had our fair share of rain and mud races and no grip problems. Safety wire also makes for easy grip changes, like if you rip one up good at the track and need to switch fast. If you get the cool safety wire tool, you can get the wires REALLY tight.
Patman
Pantless Wonder
MrLuckey said:
The wires breaks IMMEDIATELY after 'really tight' :laugh:
Typically doing a nice slice and dice job on the softer grips as well. :ohmy:
nikki
Moto Junkie
Apr 21, 2000
5,802
I usually use a squirt of WD-40 to slide the grip on the bars. Or if I can't find the WD-40, a little spit will work too ;)
Eddog and Patty: :moon:
zio
Mr. Atlas
Jul 28, 2000
2,291
My grips always twist around on the clutch side if I don't use glue (usually after a death-grip induced loop). So I've started using glue on that side only along with wire on both sides. I've had a throttle tube stick after gobbing it up with glue.
Fred T
5,272
Moto Squid said:
stupid question but how do you guys get the grips on w/o glue....I use glue/wire and the glue lets 'em slip right on.
Spray some contact cleaner on the inside of the grip. It'll slide right on and eveporates making a nice clean contact surface. I don't use glue either with this system. Just wire.
CRSpeedy
77
Thanks guys, The reason I asked is cxause I think the glue is a pain too and would be easier and faster (no cure time) to just safety wire them. I'm gonna try it for MX first.
frankrock363
60
Aside from just practice all I ride is Mx,B level.I have never had a problem using just saftey wire.If you ask me glue is just a pain in the butt.
Walt Hollis
85
I use wire and I borrow some of the wife's hair spray. The glue seems to set up to quick and then you are stuck with a grip that is half on half off.
- Walt
Philip
Dirtweek Junkie
878
Safety wire only. I messed up two pair of grips at DW with glue. It ate through the rubber.
The tool is good nikki just be careful not to go too tight it breaks the wire, then you have to cut another piece. :flame:
I must be mentally challenged b/c I can tear the whole bike down from top to bottom without any problems but changing grips gives me the blues. :whiner:
mxneagle
320
I put contact cleaner inside the grips before putting them on. This softens up the rubber and actually makes them slide on very easy. When they dry, the grip adheres to the bar quite well. Of course 3 strands of safety wire over the top. I used to use glue but this way makes it nicer to replace grips.
yz125_894
42
i use glue and never had a problem just put it around the inside just a little them slide them on. Only thing is sometimes the ends get loose later in the season.
