i have a 95 200 that is just getting its first (apparently) top end ever. i have a B cylinder. i ordered a wiseco kit after the tech i talked to over the phone said the wiseco would be just fine, no clearance problems (and they don't make different sizes).
well the wiseco piston says 66 mm on the box and my service manual says the standard inside diameter of the cylinder is 66.026mm - 66.041mm with a 66.1mm service limit. the manual says the clearance range is 0.079mm - 0.089mm with no service limit. sorry to bring math into this but i don't think i'm going to have enough clearance with the wiseco piston. 66.041 minus 66.0 equals .041 which is roughly half of the recommended range.
i took it to a machine shop to get the cylinder and the old and new piston measured (in case the wiseco isn't 66) but what do you guys think?
