wornknobby
625
i was pulling my clutch apart b/c i knew i had a worn out needle bearing, but i found out that the shaft that the basket goes onto has alittle play in the bearing.
now the play is so minimal that i can't even really feel it, its just that i can see oil move in the mating area of the bearing, so i wasn't sure if i should be worried about it much?
another question which i kinda know i shouldn't be asking, but i was also checking the crank on this side(right side) and can also feel a very, very small amount of play. the seal is blown so i didn't know if maybe this would have some affect on movement?
