Servus,
Now this is the last part (well, at least for some time ;-) of my 'backyard tuner' experiments. I learned a lot and was lucky to get some positive results. Nevertheless I'd do it again any time.
Again, I can only emphasize that the following works well for me, but very likely will not work for somebody else. I'm posting this to give interessted people a starting point for their experiments, but I do not intend to give anybody advice on how to setup their shim stacks!!!
My aim was to improve fork action on bottoming, deflecting and headshake and I think I finally (but somewhat unexpectedly) suceeded in all three parts with the addition of getting even way more adjustability on the forks. The addition of an Öhlins PDS shock and Scotts steering damper helped somewhat with the original problems, but I'm of the oppinion that the forks are the main culprit!
I would describe my result as a GNCC setup - a little soft but ok for MX and very firm for east coast type enduro, but great on anything fast with this extra safety margin for unexpected stuff. I've been racing this setup and I've been trailriding in Greece for a week with the same setup and never felt uncomfortable. For the moment I'm really satisfied ;)
Next thing will be some experimenting with the shock spring, soft spring more preload and maybe a setup for the forks from MX-Tech just for comparison - if time and money permits it!
If you haven't followed the first two parts of this experiment you can find them here
http://dirtrider.net/forums3/showthread.php?s=&threadid=5410
http://dirtrider.net/forums3/showthread.php?s=&threadid=11225
Info about the later referred updated WP parts is found under
http://dirtrider.net/ubb2/Forum28/HTML/001641.html
For setup: I'm 80kg (176lb) with gear and use the stock 0.42 springs with Öhlins 5wt fork oil, oil level 150mm.
What I did:
1) Base Valve
After having installed the new compression tap and needle with the 3mm orifices LSC was too soft, so the logical conclusion was to increase LSC even more and leave the last HSC stack untouched:
24x0.1 5x
12x0.15 crossover
22x0.1
21x0.1
19x0.1
17x0.1
14x0.1
13x0.1
12x0.1
11x0.25 clamping shim
18x0.3 base plate
18 out on the comp clicker provides a plush ride with some headshake on the fast parts - 10 out on comp is PERFECT for racing. Firm but supple, no headshake, no bottoming - I like it. The deflecting had been sorted out before with the little increase in HSC => replaced 20,18,16 shim with 21,19,17 !!! Alternatively (because 17,19,21 are not available from KTM or WP) replacing the 18x0.1 shim with a 20x0.1 would probably work also.
Highlights (most noticeable positive changes) in my experiments where the step from a 10x0.3 shim to a 11x0.25 and opening the gap (increasing HSC) from 16x0.1 to 17x0.1.
IF making some more changes (which I probably won't do), I'd add another 24x0.1 shim on the LSc part and remove the 13x0.1 from HSC - just to see the difference in LSC and HSC!
2) Mid Valve
I installed a stiffer spring (from the update kit) and left the valving untouched - no noticable effects.
3) Rebound
Together with the new tap and needle I changed to the KTM SXS spec rebound stack, but I don't dare to make any statements on the effects. All I can say is that I went from 12 to 18 clicks out and that otherwise is seems to work fine. If I'd be under pressure to make an assumption, I'd say that this helped on the headshake problem, but I've no proof for such a statement.
Comments are welcome!
Michael
What I did:
1) Base Valve
24x0.1 5x
12x0.15 crossover
22x0.1
21x0.1
19x0.1
17x0.1
14x0.1
13x0.1
12x0.1
18x0.3 base plate
2) Mid Valve
3) Rebound
Michael
