Is this ABS piston another version of the botom out aluminum ring at the bottom of the inner chamber? Or is it the plastic insert to mimic a higher oil volume?Shocknut said:The Showa ABS pistons are a much better/effective deal then playing with oil wt. Still, it is something you can do, and I typically use a 15wt in outer chamber and 5 wt in cartridge on my set ups for those that don't opt for the ABS pistons.
terry hay said:Given that the inner chamber affects damping and the outer chamber affects airspring effect and bottom out cone, it is feasable to run different oil weights. You can actually tune the effectiveness of your bottom out system by varying your oil weight in the outer chamber without affecting the air spring. Pretty cool huh!
Terry
