Crash Master
- Apr 1, 2008
- 6
- 0
I recently purchased a 94 yz250 and my buddy mixed the gas way to lean ( should have done it myself ) . the piston broke off the skirt on the exhaust side jamming the crank stopping the bike instantly. I removed the topend turned the bike upside down jiggled the crank and the offending pieces of piston skirt fell out. I have cleaned up all metal filligs and pieces and the crank turns perfectly smooth with no noise or slop. Will I be able to put in a new topend and go or should I split the cases?
Also there are a lot of little bits of aluminum from piston in my pipe , can I flush them out with water and then dry my pipe thanks for any advice.
