dirt bike dave said:Here is Rubbermaid step stool that works great as a bike stand. And you can use it as a step when loading your bike.
Might not look as cool as a custom aluminum stand, but it will only cost you about $15 and you don't have to fabricate a thing.
Humm... a full day, even at 5.00 per hour is $40, + the $25. = $65. You can buy an al. one for that and doesn't weigh 500lbs :). Then again, you don't get the pleasure of making it yourself.It took me a full day to build, but totally worth it!
Angle iron, nuts & bolts = $25 roughly
Okiewan said:Humm... a full day, even at 5.00 per hour is $40, + the $25. = $65. You can buy an al. one for that and doesn't weigh 500lbs :). Then again, you don't get the pleasure of making it yourself.
sixds said:if i can round up the steel ill build an aluminum one as well.
IndyYZ85 said:How are you going to make an aluminum stand out of steel?
