I recently, accidently bought a chain lube I don't normally run. I bought the Maxima oil and regretted it. Sure, it's clean like it says on the can, but that's because all of the oil gets blasted off the chain within 30 minutes. The oil doesn't penetrate between the links or rollers at all. The performance was so bad I ended up pouring some left over gear oil on the chain to get me through the day and it worked much better. I've also run Honda's chain oil in the past which is also very clean but doesn't last much longer. I actually really like this stuff for my bicycles because it is so clean and doesn't make a gummy mess.
But, the oil I will always run from now on without exception is Bel Ray's chain lube. You can actuall see it work its way under the rollers, it leaves a thick layer of lube that doesn't fling off. It's the only oil that doesn't leave my chain squealing within an hour of applying it.
