Mar 28, 2009
34
so when i could not get my bike started i first checked the spark plug and i noticed it was R6918B-7. its a 2001 suzuki rm125 and it calls for a R6918B-8. but it runs fine with it?
should i buy what the stock calls for or stick with R6918B-7?
mihm82
26
One thing i have noticed, especially in manuals, what the facotry says, is what they reccomend. if the bike runs fine with what you have in it, then continue to run that plug. now if the plug was the problem then yes, i would say use what they call for. wouldn't hurt to put a factory plug in and just see how it does.
Mar 28, 2009
34
alright, i wasn't really wanting to spend $30 on a plug that i shouldnt be running. so thank you.
Airbus
15
$30 for a plug?.....I just bought 2 NGK B8EG plugs for my YZ250, and they were $12 for 2....
mihm82
26
$30 for a spark plug does seem a little steep, i paid like 5 bucks a plug for mine.
zomiemama
53
Well if its running well right now i would just keep it in there. Just next time you need a plug try what stock says. I've always put what the manual says with anything esspecially 2 Strokes.
HartlandMI
12
I have an 01 RM125 and I run BR8ES. They're something like $3.50. It works great but now you have me concerned. Maybe there's something better I should be using.
rpm12505
190
Suzuki's are shakers. Stick with the $30 plug. Some tend to break the porcelain. Have seen 3 motors go down at the races in past years from it.
00KX250Byrd
27
I was buying some plugs from the local Napa store for my bikes, and the guy helping me told me the plugs for the RM125's were like 30 bucks. I couldn't believe that, but he said that is correct. Why are they so much?
Britton
OriginalRider
124
Wow my rm250 plugs are 3.49.Maybe it calls for some type of special plug.can it run any other plug in the bike?i would just buy a hotter NGK plug like a B8ES
julien_d
1,788
The only difference between the -8 and -7 is heat range AFAIK. The -7 is a slightly hotter plug. Should not cause any problem at all.
anarchy420
60
i have a 97 CR250 and im using BR8ES and BR8EG both work great. :cool:
