Just did mine the other day. Used the advice I found on here. Pick a starting point (I used the valve stem), tighten spokes 1/4 to 1/2 turn, do every third one, and go around three times. I went around a few more times, because some of my spokes were pretty loose. I used my calibrated wrist ;) to get the torque right. Seemed to work fine for me, and the bike felt fine, but then again, I'm no pro. It does seem like a logical way to do it though. Hope this helps!
just outta curiousity, would it be even better to go every 5th spoke or every 7th??
Just wondering if there would be some added benefit to making each additional adjustment further from the same side of the wheel as the previous adjustment?
I think as long as the wheel is true, every third will be fine, as long as you don't over tighten and pull the rim one way or another. Your just checking for tightness, not truing the rim.
Sorry, it's in the printed magazine. I should have specified. I wouldn't have mentioned it but it shows detailed pictures, and you know how a picture is worth a thousand words..
The nipple should turn freely, if not, it's seized. The best way is to spray some WD or other anti seize stuff in each nipple or you can take the wheel off and spray it in from the underside, under the tube. I move my spokes once a month, whether they need tightening or not and I spray some WD on them and spin the wheel in place to help with gravity. If you hold the spoke, which is OK, sometimes it will snapp the nipple at the spoke. It'll also booger up your spoke by holding it. Preventative maintenance is the best way to avoid this, especially if you ride in water once and a while.
