76GMC1500
Uhhh...
Once I torqued the spokes, the rim was way out of true. You'll have to make some adjustments from there. A new rim will have less of a problem, but mine has been pounded into the ground and onto rocks a few thousand times.
mbaird
66
exactly how do you measure the torque on a spoke??
is there a special attachment for my torque wrench??
same goes for the left front cylinder head nut on my 03
cr250
Steve St.Laurent
255
76GMC1500
Uhhh...
My spokes have allen heads on the inside. If you remove the tire and rim tape, you can use a standard inch*lb torque wrench with an allen adapter. It's not a bad idea to remove the nipples one at a time and put some anti-seize on the threads of the spoke.
mxdj666
49
just remember , when you check your spokes tighten each spoke a 1/4 turn at a time your you will pull your wheel out of true ,unless the spoke is super loose tighenen it till the nipple touches the rim and then go from there.
