I have an '05 YZ250 and I weigh 213 lbs. I ride motocross mostly on a sand track. I put a 5.2 rear spring on it as per Race Techs spring calculator and when I set my race sag to 95mm I only have about 6mm of free sag. First of all do I really need to go to a stiffer spring to get the free sag better? Also, how do I know what Spring to buy next in order to get it in the proper range? Would 5.4 be sufficient or do I need to go stiffer? If the calculator said go to 5.2 and that didn't work it's only a guess to know where to go next. At $109.00 a pop, you would think that the spring rate calculator would be a little better.
I had the race sag set at 105mm and I had 18mm of free sag. I went to the track and let a couple more experienced riders try it out and they said the front was to light. They told me to go to 95mm of free sag and lower the forks in the clamps. They told me to make those adjustments then they would help me set the clickers this weekend. So when I went to 95mm of race sag that's when I only ended up with the 6mm of free sag. I ordered a 5.4 from Race Tech today so if any body has experience with this bike I would welcome the input.
