kstout4life
86
how much of a difference will adding 1 or 2 teeth oin the back sprocket be? some turns are too wide for 2nd gear, but i try 3rd and have to use the clutch alot. theres alot of jumps right after the turn so i need to pull harder coming out, but i dont want to be shifting alot mroe than i am. what do u guys suggest? 1 or 2 teeth?
Chili
Apr 9, 2002
8,062
17
Only testing will tell which you're going to prefer. I'd try to find a couple of cheap sprockets and give both a test. Always good to have sprocket options if you ride elsewhere as well.
