Crimeidy26
- Aug 6, 2008
- 40
- 0
Ok guys here goes... I rode the bike last weekend and it cranked as it has in the past on the first kick...Tonight i installed a new clutch cable as the other one was worn out and i went to crank the bike to check to see if i had the clutch adjusted right and nothing... Me and a buddy kicked it for an hour and nothing except for a few bruises on the shin from slipping off the kick starter. I checked the plug and it was somewhat wet so i know its got gas, i leaned the bike over and it ran out of the carb overflow under the bike, I took the spark plug out and kicked the bike over and it was sparking blue lightning bolts. I then adjusted the air screw in every direction and then put it back to where it was when it was running fine and still nothing. I'm baffled and its making me hate this thing more and more. I've never had a starting issue with this bike it usually starts on the first kick or second kick everytime, and it rode beautifully last weekend. Any ideas as to what it could be causing it not to fire because i know its got got spark and gas and im assuming air because the air screw is back to the original location and i've moved it in every direction. I'm stuck any ideas would be appreciated. :bang: :bang: :think:
