Stator output on 1991 KDX-200 ??
longshore58
92
Manual says 35 watts for headlight and 10 for the tail light.
Does anyone know what the mamimum wattage is that the stock stator will safely support as far as lighting goes??
I'm looking to install an Acerbis Blitz with the following specs:
"Dual 35W halogen lamps supply unsurpassed illumination'
38 degree flood beam; 10 degree pencil beam.
Central heat-resistant unit accepts bulbs up to 50W"
From the looks of it I know I will not be putting a 50 watter in it and probably will be limited to running only one of the 35 watters at the time using a high/low beam switch....
OLHILLBILLY
77
I think 40 watts is about the max, maybe 45 on a '91. My manual doesn't go back that far so I'm not sure. Do away with your tail light and the stock lighting coil should support one of the 35 watt headlight bulbs at a time with no problem.
fusion
53
My 89-94 kdx 200 service book says 30W for headlight and 10w for taillight.
longshore58
92
It is only 30 watts front and ten rear according to my manual.....not sure why I typed in 35 watts for the front.........wishful thinking maybe??
