Steering Issue *Pics*
Well, after a while off the bike, I decided to hop back on today. The rear tire was worn so I replaced it and reinstalled the rear wheel. Everything went fairly smoothly, retainer clip on the chain was annoying to get back on, but all was good.
I went to take her off the stand, and the front wheel would turn left about 2 inches, and turn right about two inches. It was stiff as could be. I shook it a little, applied more pressure, then it turned all the way like it should. Thought it was strange and continued...
I started her up, went for a slow ride around the block and noticed that the turning was horrible. It was stiff, hard to turn, and once it started turning it wanted to pull me all over the place. Got back to the driveway, put more air in the rear tire, took off the front fender in case it was hitting something, sprayed some WD-40, and went for another ride.
It did the same, but not quite as bad, although I can definitely still feel it. Has anyone else had the same problem? The bike was on its stand for only about a month, and the front wheel was never touched. All spokes are tight, front and rear.
What could be the problem?
CROSS
CROSS
