Occasionally my throttle will stick open, usually when I've been on the pipe. If I pull the clutch in it normally unsticks within a couple of seconds. It only occurs intermitently and I can't reproduce the problem with the bike on the stand.
I've checked the slide and its all OK, no foreign debris to make it stick, and the needle isn't coming too far up at WOT. Of course I've checked for frays etc, cable seems to operate smoothly.
The only thing I can think of is that last time I had a frayed cable I got a new cable put inside the old case - maybe I've got a minute kink somewhere.
Anyway, I've ordered a complete new cable assembly in the hope this will cure it.
Has anyone else experienced this problem, and if so what was causing it??
Cheers,
Andrew
96 KDX200
remember: skin grows back!
Cheers,
Andrew
96 KDX200
