2-Strokes 4-ever
My 03 RM250 won't idle consistantly.
-All new motor with only 25 hrs.
-Good reeds.
-Float height is correct, jetting is good, carb is clean.
-Muffler freshly repacked.
-Powervalve clean and working properly.
-Timing right on.
-No air leaks in air boot, intake manifold, main seals, cylinder-to-reed cage, reed cage-to-carb junctions.
-Good plug.
-Fresh 93 octane mixed at 40:1
I warm the bike up, ride it around to operating temp, set idle and back out air screw till peak RPM, but no more... (2 turns.) Good idle.
Run it hard in the tight woods and when I stop, high idle (rrrring.....ning....ning...ning.) Very hard to start when warm and idling fast.
Even my friend and excellent mechanic is stumped.
Would a faulty TPS cause these symptoms? It's about all we can think of that's left to check.
Thanks guys
-Good reeds.
-Timing right on.
-Good plug.
Thanks guys
