Curious if any of you out there have any experiance using the fork - sub tanks/ air tanks for MX? If so leave a comment. What is the best way to set up the system?
Do you setup the rebound and compression that is best on the bike, then add the tanks on?
Also, once on, how do you adjust the compression clickers if the handlebar is covering it. Today I use the Ride Engineering compression adjuster, but if I add the sub tank, I can;t use the ride engineering dial to adjust the compression for different tracks because the bar is blocking it.
On todays MX bikes, is it really any advantage? I know for trail riding possibly.
Any advice is appreciated.
Thanks,
Spokes574
Thanks,
Spokes574
