sweetjeep
57
Sawzall.
Cut it and reweld it. Or if it's aluminum (and you can't weld it), put a "blank" inside and bolt it back together. The blank will prevent the walls from collapsing when you tighten the bolt.
By the way.. it doesn't lower the bike, only the seat. And it will lower from the rear forward!
marcusgunby
6,450
BTW off topic -just watched san diago, reeds bike seizedin the qual, then in the main his brakes go out-not sure i would feel happy with that!!
