Bishbash25
- Apr 19, 2009
- 5
- 0
Hello all i have recently purchased a 2001 rm 125 very cheap as it had a non starting problem.
what i found problem wise was piston had worn well not to sure what had happened but ring was stuck in where piston worn away and burr on top of piston.
Looking at cylinder bore was ok so don't know what caused it? but could only replace a piston that was taken out of bike few months ago along with ring (looked fine)
Fitted piston and started the bike fired first kick but there is a sort of rattle tapping noise thought at first was stone in exhaust but checked.
Also i did not take exhaust port apart and check could that be a problem? or could small end bearing on conrod causing rattle or is there a major fault i am missing.
Am i right if piston was wrong bike would of told me by now and stopped working?
Need help or advice from anyone would be grateful.
Bishbash25
Bishbash25
