Harry Reed
- Oct 1, 2001
- 20
- 0
Sorry, I forgot to suggest a running temp. Say 275-300 deg. ?
I just called Harry and spoke to him. His shop is only about 20 minutes from my house. He sounds very interested in doing the testing and I think it will be good to find out for sure what the REAL deal is with all these fluids. I have been just buying the expensive stuff and wouldn't mind knowing for sure if I'm throwing my money away or actually buying good stuff.Originally posted by Harry Reed
Jer,
I would like to offer some help on the subject of fluids. Why don't you send me some of your shock fluid. I can run that, mobil 1 atf, and some other off the shelf shock fluids on my dyno. I'll send you the dyno sheets when i am done. Then you can post them. Might be pretty informative !
I am pretty open to finding new and better shock fluids.
Call me if you want me to do this.
Harry
Good point. Harry said he would test the fluids at room tempreture and at an elevated tempreture (forgot the number) to see which one fades. I don't think you could run a test the right way without seeing the results at higher operating tempretures.Originally posted by svi
We used to suffer problems with fade and inconsistancy in shock operation on road race shocks after about half race distance, we've pretty much cured this by using a combination of Silkolene Pro RSF 2.5 suspension fluid which has a VI of 464 and by pre-heating the shock with a shockwarmer.
As far as the shock fluid, it is simply water.
