Tips on how to clean the rubber chain guide?
TONY78
25
If it is the part i think your talking about, you have a plastic/rubber slide on the swing arm and, depending on your bike, a rubber/plastic roller on top. I usually use petrol or turps on a rag to clean off all the old chain lube and grime.
XtremeAir125
120
Thats ok too, but I was talking about the I think it's called the chain block? The rubber piece that fits inside the metal thing? It's located underneath the sprocket, is petrol petroleum? And what's turps? Thanks!
smb_racing
Master of None
2,085
petrol is petroleum, turps I'm guessing is turpentine or mineral spirits. Get a skinny nylon brush and some simple green or other degreaser. Spray the block and let it soak, then just brush off the crud.
