I am curious as to what each number on a tire stands for. I've also noticed a possible difference in dimensions-possible between a tire with given measurement in metric as opposed to standard unit.
Can someone give me the explanation?
The first number given in the tire width in milimeters (100 = 3 15/16" also called a 4.00)
The second number is the aspect ratio; i.e. the height of the tire in relation to its width (a 100/100 tire is as high as it is wide).
The final number is the rim size in inches
