redneckshredder
- Mar 23, 2008
- 9
- 0
ok i just bought a 98 kx125 that the guy said had Carbon Fiber Reed Valves, Wisco Piston, Hot Rod Connection Rod, Moose Main Bearings, Cylinder is renickel coated and that it ran great and he would ride it anywhere. when i brought it home, it ran great for about two hours,lots of power and then while riding about mid rpm, i accidently hit the kill switch and the bike bogged down and died, wouldnt start and has no compression at all in the kickstarter. also i changed the spark plug and the old one had a broken tip on the part the goes in the cylinder. any ideas is this just a top end problem? i can still shift through all gears thanks
also how much would a typical shop charge to do either a top end or bottom end on this bike?
