tony91
- Jan 30, 2002
- 493
- 0
Is it a necessity to torque the flywheel and primary gear bolts? When I did the bottom end I torqued everything to spec. I'm replacing both main seals and used an impact wrench to remove the bolts. I don't have access to a gear holding tool I used the when the bottom end was done. Should I ust use the impact wrench to tighten. Or, does anyone know a trick to hold the gears so I can use a torque wrench?
