Rhodester said:It doesn't have to do with throttle position, but the RPM range you ride in.
There is, "quite a lot". I found the torque pipe to really beef up the mid-range. The bike would pull a lot stronger through loose, power-robbing dirt than with the stock pipe. I didn't find a huge difference off the bottom.If you've used both, how much difference is there between the two?
