Tuesday was a gorgeous, sunny, warm, summer day. The deep blue sky was filled with puffy white clouds, just a touch of a breeze out of the west … too nice a day to waste on yard work, so off I went to ride the Kalkaska Trail C Loop. This section of the Kalkaska system is the southernmost loop which starts at the Trailhead parking facility located a few miles west of Grayling on M-72. The C Loop is approximately 31 miles in length and is 50” trail suitable for ATVs and motorcycles. Although reasonably wide in most sections, after all the rain we have endured this spring, this trail has many challenges to keep riders of all skill levels interested.
I arrived at the trailhead around 1345 hrs to find it empty of visitors and apparently under rehabilitative construction. The parking lot has been recently graded and there are many tree stumps piled around the perimeter. A functional, but not very clean, restroom is available. [See photo below, left]
After quickly unloading and gearing up for the ride, I took off in the CCW direction as past experience has taught me that the steepest hill climbs are encountered by traveling in this direction. Basically the trail has three separate sections. Beginning at the trailhead and proceeding south [CCW] to point #12 on the MI DNR map you pass through heavily wooded and hilly terrain that is relatively easy to ride … I found the trails to have many puddles and muddy spots but nothing serious. Because trail composition for most of this section is a sandy loam, the surface was basically hard with excellent traction so the going was relatively fast. Erosion is evident on many of the hill sides, but the trail is not heavily grooved or washed out. Tree roots eroded free of soil but still covered with slick mud are the greatest obstacles to be overcome … the forest is almost fully in bloom … the leaves are fresh, large and very green. Vines are beginning to creep into the trail in the brushy areas and the thorns are beginning to emerge which makes long sleeves a desirable item if you want to ride at speed and return with any skin left on your arms. [See photo below, right]
