Trailer tires from Harbor Freight
JWW
2,529
I need to pick up some ne 4.8 X 8 tires for my trailer. Harbor Freight has some for 29.99 mounted on the rim.
Have you guys or gals used tires from Harbor Freight? Any bad experiences?
Jeff
a454elk
Mexicutioner
7,538
18
Hey Jeff, their stuff is fine, no problems that I've heard of. If that doesn't work I know that JCWhittney has some too.. Good luck
JWW
2,529
The family couldnt decide on a weekend so I told them to enjoy the tents :p
When my boy is here I need the trailer for all the bikes. I can get them in my truck but its a tight fit.
Jeff.
If you use those tires, be sure to put inner tubes in them. I believe those are tubeless and they will pop a bead pretty easy if you get a little off the road.
Ask Longtime about it. :scream:
JWW
2,529
Thanks for the advice.....Everytime I put the bikes on the trailer I worry about that. I do run a strap through the tires. Hopefully if one of the main straps fail the one through the tires will hold it on the trailer.
a454elk
Mexicutioner
7,538
18
Rent a U-haul! If the tire pops, keep draggin it:):)
