At the moment we are using some Putoline light gear oil, but I am beginning to think that maybe this is causing a problem with our transmission. When the bike is cold it shifts fine through the gears and really smoothly, but once the bike heats up we have trouble shifting past second gear unless you drop the revs slightly. Do you think that since our bike is pretty old now (1995) that it doesn't like these high grade specially formulated transmission oils and would probably run better with 10w40 motor oil?
The bike more or less fine before switching to this oil so it has got me thinking a bit.
