Has anyone else experienced problems with the TTR125 rear sprocket mounts coming loose or breaking out the hub? It seems like the bolts and sprocket configuration on this bike is very old fashioned. I seem to remember seeing this type of setup on trail bikes in the early seventies. They use straight studs with fold up locking tabs with nuts. I have already had one hub break apart and always have to tighten the bolts for every ride. It sure would be nice to see a conventional modern setup with conical seat thru bolts and tapered holes on the sprocket like you see on even the XR100. Has anyone here addressed this problem yet with a new type hub and sprocket?
