Tonyklem
63
Hey guys, my twist throttle has been sticking for a while. i can manually turn it however i want and it responds, but if i just puill it back and let go it sticks there. What are all the possibilities for this problem?
i know the slide etc are moving freely, i think it may be the cable or something with the twist throttle itself.
titoislaidlow
30
Thats actually a problem that could get serious if you fall off the bike. Its most likely the throttle cable. Easy fix. Take apart the grip and throttle and clean all the dirt out, put a little grease on it, that doesnt work swap out cables and happy riding.
CaptainObvious
Formally known as RV6Junkie
3,331
Is the end of the grip rubbing on the bar end?
psalm3124
101
Go with the first two suggestions (cable & throttle tube rubbing), hopefully its one of those two. If that doesn't do anything, check the carburator slide.
Tonyklem
63
hmmm actually now that i think of it, it started happening after i dropped the bike on the right side. maybe it bent the throttle.
TimberPig
859
More likely it shoved some dirt in that is binding the throttle tube up.
Tonyklem
63
well i had taken it off before and put some grease in there. would that help? if anything i think it might have bent the plastic tube part.
TimberPig
859
I would think it isn't bent, as plastic doesn't normally bend and stay bent very well in an application like this. It is more likely the tube is bottoming on the bar end, or there is dirt jammed in there. The tube could have shattered, but a plastic throttle tube simply isn't an item that will hold a bend from an impact on its own. You could bend the bars inside the throttle tube and cause it bind as a result, but it isn't the plastic tube there, it is the metal handlebar end.
Tear it apart, clean it again, check the bar for straightness, and correctly reassemble and your problems will most likely be gone.
