I have done alot of searching and reading on jetting and have played around with it on my '95 200 which has 1/2 of the air box removed, and a FMF Rev pipe (k-30). Right now I have a 158 main, 45 pilot, AS 2 to 2 1/2 and a 1174 in the middle position at 17meters above sea level. The top end was done this winter, compression is 190. Overall the bike runs great with a slight bog if at low speed in 2nd or so when the throttle is rolled hard from closed to open. When it's 'on the pipe' it will lift the front wheel in at least 3 gears with just the throttle.
A couple of things that seem not right, one is that I don't have to use the choke to start it, normally it just takes a couple of kicks to start. I tried a 42 pilot which seemed to work OK but I was a bit fearful of running lean and the crackling sound that I had become used to was gone, just hearing the motor without crackling when I let off the gas seemed weird. Kind of sounds like a 'ting ting ting...' make sense?
This is my 1st dirt bike and I am now getting comfortable enough to pay attention to how it works. When I bought this last fall I was just happy to have it run and me stay on it, but am becoming a bit fussier now.
Any comments?
Any comments?
