Status
Not open for further replies.
mhenry14clady
37
Hey just got v-force 3 reed block for my rm 125 and it says you needa remove the standard reed cage. Could any of you's give me a detailed step by step instructions in how to do this as i don't have the user manual? Thanks:)
fordmugg
the boot that goes from the carb to the cylinder thats where the reeds are ....so loosen the carb unscrew the boot to the cylinder and take the reed cage out and then just go into reverse to assemble
mhenry14clady
37
what do you mean boot? what does it look like?
yes i got the manufacturer's instructions with the v-force but it doesn't tell me how to remove the standard reed block in order to put the v-force in
If that isn't obvious just from looking at it you should have spent your money on a service manual instead of a reed block. :|
Buy a manual, it will answer this and lots of other questions.
Status
