My son's 2001 YZ250F suddenly came down with a case of no start. After cleaning the carb and trying again tonight, no go. The bike give a few revs of ignition, but not much more until it finally floods out completely. Normally it's a 2-3 kick starter.
We then checked the valve clearance. In March all was OK, now the center intake clearance is at less then .05mm, the the two exhaust valves were tight. The major concern is the center intake valve. I can re-shim and bring it back in line, but why did it get so tight so quickly? This bike went for two years with no change in the valve clearance, even after a top end rebuild this winter (the March check - OK one was off because I initially didn't get the shim in right..)
Can the experts here help me with a root cause for the what appears to be sudden valve tightening? Thanks for your help!
