Looks like I got a little deeper then I am capable of. Just took off waterpump cover to change oil seal due to milky gear oil. Anyway I pulled off cover- impellar, and then started pulling on spring which was part of mech water seal. Bad Idea. Spring popped out and behind there was a little rubber boot that looks like the spring either sat in or over. No idea it popped out pretty fast. Has anyone ever been up against changing the oil seal? and if so should I be attacking this by pulling the clutch cover off to remove the whole gearto get at seal? and lastly did I ruin my mech water seal by pulling spring away from that rubber boot? any help would be much appreciated.
thanks
thanks
