As long as you position the steering head bracket as low as possible in the hole, and use the thicker spacers on the arm, the angle is very slight. The bracket bolt actually rests along the bottom of the hole.Originally posted by Braahp
Mine fit better when i went ahead and drilled the frame. I had too much angle when I used the "big" hole of frame.
Originally posted by ChuckyBoy
... I wouldn't be suprised if a Bot has already scoured the net and picked up your addy. You'll probably be on a dozen new spam list now.
