thats what I thought.I ran 40:1 first tank(synthetic).It was fine.My plug was fouling everyother ride,and tons of spooge>BUT,silencer had no packing!!I had it repacked and had the carb worked on(he said air bleed was screwed all the way in,getting no air).Now the thing hauls.Has tons more torque.But i threw it down the last time I rode when my son wrecked.Now it will not start,there was fuel running out the overflow.I think I filled the case or cylinder with gas.Next Im gonna change plug,drain case and let air out.How much oil does a 2000kx 250 take?TRANS TOO??oh ya--thanks in advance!!
Just change the plug there is no need to drain the case. Kick it over a few times with the spark plug out. The case oil is the oil in the gas, you dont add it like a 4 stroke. The amount of trans oil is usually stamped on the right side case by the filler plug. Your bike probably takes 750ml's which is the same as 750cc's or .75L
