Makes me realize how lucky I am: I ride the trail bike out of my shop/garage and five minutes later I am in the river bottoms, bouncing off trees! Let's me ride almost every day for an hour after work....howes said:My sister has a farm about 2 hrs away where we ride . There]s about 9000 Acres to play in . I have been trying go for weeks ,but always somthing pops up & I can't go . This weekend is must !!
This came off as rude? Straight information without guy figuring involved is not rude, its fact. "When/if I get really anal, I will run a tad richer oil ratio", and starve it for gas? See the point? Any decent premix, at the factory recommended oil ratio, and heat cycle it. Even that is not recommended on some models, but I do draw the line there. I like heat cycles on all rebuilds. The entire new engine needed break in time, an over haul is substantially less.mudpack said:If you've assembled the components to factory clearances, you can use whatever oil you normally run...and at the ratio you normally run.
There is no benefit from using a special oil and/or special mix ratios on a fresh two-stroke. When your bike was brand new, it had all new components. The factory owners manual did not specify a special break-in lube/ratio on a new machine. That tells us much.
Break-in procedure is important. Break-in oil is not; use a good name brand, conventional or synthetic.
You are assuming/figuring again. I did not see the edit, coffee is very good today, day off even better!julien_d said:I have no idea what you're talking about, honestly can't make much sense out of that. If you were referring to my post though, the "that came off as rude, sorry" comment was directed towards my own post before I edited it due to rudeness.
Don't drink and post people! It's bad practice...
howes said:Wow ! What happen to this thread ? you would have to be Einstein to follow it .
