..Originally posted by bigred455
I have tried them all,from belray,amsoil,valvoline.motul,to mobil1.Mobil 1 15 /50 or their 10/40 motorcycle brand is no doubt the best for my 00 kx 250.The shifts are consistent (POWER ON) clutch pull also stays very consistent when the clutch gets a good work out.I have noticed with other brands when you are really working the clutch I lose my free play in the cable ,(TIGHTEN UP) with the mobil 1 it just simply stays the same lap after lap.No other brand that I have tried comes even close,well maybe the belray,but mobil 1 their is a noticeable difference.None of them touches the shifting department.I try to stay with their 10/40 motorcycle brand 8.00 .qrt,they say it has more phosorus and zinc than the 15/50 which aids in wear better.The 15/50 for automobiles has less because they use catalyic converters.RICH ;) I cannot tell the difference in performance between the both. ARE YOU GUYS STOKED I AM STOKED. :scream: :scream:
....Originally posted by bigred455
I would like to take back what I have said about one of the oils I have tried recently.I was trying out the amsoil 10/40 mortorcyle oil in my tranny.My shifts were becoming very inconsistent on the track(very sandy).It was also muddy in alot of sections.I was cursing the oil for the mis-shifts.It was at the end of the day,so I was packing up.I took a quick look at my bike and noticed the chain had no slack what so ever,my chain was adjusted perfect before I started cutting laps.The mud caused my chain to tighten up really good, so this would not be a fair test for the amsoil.Any kind of oil that you use with a tight chain, the shifts will suck. I will give the amsoil another shot..ARE YOU GUYS STOKED I AM STOKED. :scream: :scream:
