Apr 7, 2008
61
i have a 2003 yz125 and it only has 5 gears. i also have yz80 with 6 gears. it seems like almost all motocross bikes have 6 speed trannys except mine. Is this the way yamaha made the bike or was it something someone did to it?
Deadohiosky39
146
Every bike i've ever had has been 5 except a kx60 when i was younger which had 6. I was thinking some bikes even had 4 gears. Like the yz400/426 or some of the big 4 stroke ktms maybe. I'm not positive.
XRpredator
AssClown SuperPowers
13,504
the YZ125 went back and forth between 5 and 6 speeds in the last few years. I'm not sure when it had which, but there's nothing wrong with your bike.
motodr9
184
Oem
In 2003 Yamaha put a 5 speed trans in the YZ125. I guess they thought weight savings and lower production costs were the way to go since everyone was buying four$trokes.
IndyMX
Crash Test Dummy
5,548
Amo, IN
Most people don't use anything more than 1 thru 3 anyway.. so what's the point of having 6 ?
On my 450, I know for a fact that I have never had it in 5th gear on a track.. Might as well take that gear out.
The 2 stroke haters stole 6th gear to keep it slow enough for the 250fs? Joking! 3rd gear will put most people in the hospital. As said, Yamaha made it that way, it said so in the brochure.
2-Strokes 4-ever
1,842
4
Missouri
Yamaha makes a really good 125 motor. They thought it so good (fast and powerful) that they could get away with a 5 speed, even though all other 125's have six.
The Yamaha still needs a six speed IMO, but I don't know if that short coming is enough to NOT buy it. It's still a good bike.
XRpredator
13,504
Honda had a five speed 125 for a couple years too, so don't think Yamaha invented the concept.
2-Strokes 4-ever
1,842
4
Missouri
Oops, I stand corrected.
Dumb idea by Yamaha AND Honda then.
cowasucky
170
I bought an 03 yz85 which does have 6 gears, but I could only get 5. I switched to a heavier transmission oil (Belle Ray 85w) instead of the 10w 40 the prior owner had in it and viola........ 6th gear !!!!!!!!!
mas2de
Alot of mx 2 strokes that I've heard of played around with gears.
Deadohiosky39 you are correct. The larger mx 2ts tended to have 4 speeds while alot of the small bikes had 6. I believe it was all for close gear ratios. Not for any o/d.
I know a somewhat common mod for the old Yamaha YZs was to put and IT (enduro 2 stroke) bottom end in it so they could have the 5 speed instead of 4. As far as I know all the enduro bikes had an extra gear. I'm not sure on the ratios though, or how exactly they compared to the mx.
adam728
1,011
OriginalRider said:
2003 YZ125 is a 5 speed.Those bikes make great HP to about 37+ with about 25+ FT LBS that's very good for a 125.
Try 32-34 hp, and around 15 ft-lbs of torque.
Most manufacturers have jumped around on the number of gears on bikes. The main reason for going for fewer (6 to 5) is to save weight and make the cases narrower. If you drop a gear out you can narrow things slightly, make the remaining gears stronger, and shave a bit of weight. I think most 125's have jumped between 5 and 6 speeds, and 250's have mostly been 5 speeds. 4 strokes came along and 4 speed transmissions became very common.
