what's up, ok to start out with this is what i did to my 1988 yz-125 i put in some new moose crank bearings and seals moose complete gasket kit then the wiseco hotrod piston rod kit had it trued with a jig and even a new wiseco piston. got it back togather cleaned the carb then it woulden't crank with the kickstarter me and my dad had to roll it off. then i pulled in the clutch to stop and it wouldn't disingauge me and my dad took the right side crankcase cover and looked at the clutch and went back through it at least three times and put it back in exactly the way it's suppost to go and it still does the same thing.
second of all it doesn't want to run right at all it seems as if something is bogging it down we rejetted it and it still want run right and then water started running out of the over flow on the radiator and it want stop and im really starting to get mad :bang: any help would be appreciated thanks
