mandark1967
- Mar 12, 2007
- 246
- 0
I performed a search, read the FAQ's (good collection of information, by the way!) and I read the jetting guide on the just KDX section. However, I still have some jetting questions I need some help with. Specifically, I'm looking for a decent jetting baseline I can reliably run
CLIMATE BACKGROUND:
The area I live in (Memphis, TN) experiences major temperature and humidity changes during the day from Springtime until late Fall. We often have temperature swings that can exceed 50 degrees between the day's low and high temps.
Additionally, in the summer it is pretty common for the temps to be in the range of 98-106 with over 95% humidity one day while the next day has 30% humidity and temps of 85 degrees.
This climate, combined with the mods to my bike, has been playing havoc with my atempts to dial in my jetting, and I need some assistance, please.
BIKE INFO:
1998 KDX220
35mm Keihin PWK35 Carb with "stock" jets & needle
Note: I bought a brand new 35mm from Sudco and have made no changes to the jetting it shipped to me with yet
FMF Gnarly Rev Pipe and Turbine Core II SA/Silencer
Fredette's Torque Ring not installed (but I have one)
STOCK airbox lid (snorkel remains)
Fuel to oil ratio of 40:1 (90+octane and Suzuki CCI)
I will be installing Boyesen Carbon Reeds when they arrive
I have (believe it or not) a completely stock airbox with snorkel, but I plan on it and placing (6) 3/8" holes in the top of the airbox
Without the Reeds and Modified AirBox, the bike seems to run well in the low-mid throttle setting. It runs rich...but not so badly that it sputters.
It "loads up" between 50% and 80% throttle. From about 80% to WOT, it becomes smooth again and accelerates cleanly.
My assumption is that the needle jet/main is most likely the culprit, but I am worried that dialing the jetting in so closely to a "particular" temp/humidity setting would cause problems when we get a large temp/humidity swing...
I am thnking I should, at a minimum, raise the clip 1 notch and go 1 size leaner on the main. Currently, the plug is very black (the part down deep, not the easily viewed tip) so it seems it's far too rich.
Do you think that leaning it out a bit with the temps in the mid 50s would kill it when we hop back up to 80?
Does anyone have a suggested range for jetting that would be reliable, while not fouling too many plugs?
CLIMATE BACKGROUND:
BIKE INFO:
1998 KDX220
