northrivertom
4
Hi There New To The Boards...i Just Picked Up A 2000 Yz 125..can Anyone Tell Me How To Find Out The Stock Number Of Links For The Chain..and The Stock Sproket Numbers..front And Rear..im Not Sure If This Is A Basic Question...i Could Go To A Dealer Although Im Sure Someone Out There Know...thank You
sharky243
246
I'm guessing your bike didn't come with an owners manual ? All that info should be in it. The stock sprocket sizes are a 13 tooth front, a 48 tooth rear, and the standard chain type and length is #520 x 112 links. I recomend a 50 tooth sprocket on the rear tho. 125's just don't have the torque to turn a 48t well out of the hole.
northrivertom
4
sharky 243...thank you...so the chain is 112 plus the master link..?..if i set up to the 50 tooth can i use the same 112 length..thanks again
FRESH VIDEO
