i recently put a new crank shaft into my yz along with new bearing and seals. i was riding it around and after a while its would bog down on me. i checked the spark plug and it was oily and had no spark. i replaced the plug and started to have the same problem. is there any way i could tell that its the seal leaking or maybe from the case. i did put gasket sealer on the case befroe i put it back together.
