YZ To WR426 transmission????
MT92
13
I have a 2000 YZ 426 and would like to find a transmission from a WR to better gear it for the woods. Has anyone done this and if so could you provide details?
SFO
2,001
it is a drop in for your application.
Most guys I know just run the wr 5th gear set for a OD, and gear accordingly
MT92
13
That is great what would be needed for a 1st and 5th gear swap? Would gearing from a 2000 Wr go right in?
Thanks Mike.
MT92 said:
How about the transmission from a 01 or 02 wr426 does anyone know if that will go?
Should be the same. Go online and check a parts fich to compare part numbers with a '00 and count teeth.
nz_farmboy
Does this mean I can swap 02 WR ratios into my 02 YZ?90km/h just doesnt do it for me....only need to swap 1st and 5th....Where can i get these parts?
Thanks guys
Thanks guys
Yamaha. There is a list of part numbers that is in a thread in the Two Stroke forum.
Gear, 3rd Wheel 5BE-17231-00
Gear, 3rd Pinion 5BE-17131-00
Gear, 4th Wheel 5BE-17241-00
Gear, 4th Pinion 5BE-17141-00
Gear, 5th Wheel 5BE-17251-00
Gear, 5th Pinion 5BE-17151-00
The thread did not list the 1st or 2nd gear but it is available from Yamaha. I'm looking to make my YZ 250 two stroke into a WR.
Yamaha parts fishe:
http://www.yamaha-motor.com/sport/parts/home.aspx
