slapshot1540
53
just got dun rebuilding the top end on a 99 yz125 that i bought already taken apart. runs great except for the clutch. it didnt seem to do this wen i first started it, but now when i hold the clutch in while in first gear it wants to go but wen you rev it up while still holding in the clutch its fine it doesnt want to move at all. what is this?
motodr9
184
You are not low on trans fluid, right?
You clutch springs could be sacked-out or the plates and fibers could be hanging up.
Open up the clutch cover and take out the clutch pack and separate and inspect fibers, steel/alum. plates for warp or breakage. Sometimes, simply separating the clutch pack can free up sticky plates/fibers and allow proper action.
Check clutch springs free-length and clutch basket for notches also.
It will take you 15min. tops.
