I bought a 2001 YZ250 last week. Took it home rode it 45 minets and it ran great. Stoped to rest and it would not start. Found it had coolant in the cylinder. I tore it down and found ablown inner o ring. I had the head resurfaced and installed new o rings. I also pulled the cylinder and visually checked for cracks and could not see any. I put it all back together and with a new plug it will run for a few seconds and then die. When I pull the plug it has water on it. I clean the plug and it will start and run a few seconds again. I also changed the lower end oil. Where is the water comming from??
