Yamahauler
127
Someone please tell me I don't have to remove the entire right side crankcase cover to get the clutch basket out. Am I missing something here?
Yamahauler
127
I've spun the nut off using the impact. Problem is the basket won't fit through the opening in the crankcase cover. I have no idea why Honda did this. This must be a design error.
Jaybird
Apprentice Goon
6,452
Charlestown, IN
So, you have to split the case to get the basket out?
IrishEKU
A General PITA.
3,808
Sure sounds like it. I had to pull the case cover to get at mine. Even thouh it's an old Zinger.
bscottr
1,255
I believe the gears on the outer basket are too large to fit through the clutch cover, not certain though. In any case, it's not difficult to remove the right case cover. Just insure you pay attention to reinstalling the kick starter mechanism as there are alignment marks.
Drain the tranny fluid and coolant. Remove your kick starter and remove the water hose. You may need to remove the bolt from your rear brake pedal for clearance. Fairly straight forward job.
Good luck,
Scott
Rcannon
1,886
I imagine Honda intended a person to replace plates through this hole. Not the entire assembly.
Come on now. Who does not love replacing $25.00 gaskets????
Maybe it is not a bad idea to have a good look inside the entire cover?
Joepro9
503
